ABAP Connector: How can i run transformation after uploading P2P ABAP reports ?
Hello Everyone,
I am currently facing the problem that after uploading the ABAP reports for the P2P Connector in Celonis i cannot run the transformation.
image 1
basically in the training about the ABAP extractor, they advise to run the transformation after uploading the reports. However as soon as i execute the data job for the SAP P2P full transformations I get the following error message.
I have the feling that the JOB does not find the ABAP reports that i uploaded. or i am missing a step here :(
I appreciate a lot your help to solve this matter.
Thank you in advance.
Omar
dennis.pflug
Level 6
Hi Omar,
  1. have you checked within Data Integration that the ABAP reports are available? E.g by just executing SELECT * FROM EKKO to see if that is working.
  2. Please check where the ABAP reports are getting stored: Is it within "Global Jobs" or within a specific data connection? And in parallel in which Scope are you executing your SAP P2P - Full Transformations? In case SAP P2P - Full Transformations is assinged to a specific System Connection (e.g your SAP system) but ABAP Reports are getting stored within "Global Jobs" you must switch SAP P2P - Full Transformations to your global job or copy the ABAP Reports from Global Jobs to the scope where your transformations are getting executed.
It is not possible to access "global jobs" tables from transformations stored an executed within a specific scope like SAP system. But it is possible to access tables from different scopes within Global Jobs by adding the relevant Schema in front of the table name.
Hope this helps you.
BR
Dennis
Hello Dennis,
Just to let you know i am not connected to any SAP System ! however, I only downloaded the ABAP reports and uploaded them into Celonis. should it also work ?
I store the ABAP reports under ECC Transformation as shown in the image below.
imageyou can also see that the P2P- Full is assigned to the System connection ECC
image.pngI tested to check if the tables are present in ECC and they are not.
I followed exactly the steps shown in the Training https://academy.celonis.com/learn/video/one-time-sap-upload-with-abap-generator-uploader . But was always receiving an Error during the transformation.
Omar
dennis.pflug
Level 6
Hi Omar,
what is shown within "Execution History"?
You can find this in File Uploads section click on the three dots of one of your successful ABAP reports (e.g again for EKKO) and let us know what is shown there.
Just for testing purposes have you tried to upload an excel file or any other file to see if this file is getting stored within the ECC scope?
BR
Dennis
Hello Dennis,
This is the Excecution history for the ABAP Report EKKO.
imageWhen i upload an excel it definitely appears in the ECC Scope as whown
Omar
Hello Denis I think i have found the probelm
My ZIP files were not well organized inside: I should access three folders before accessing the CSV File. and thus Celonis was not uploading the files.
Thank you very much for you kind help however.
Omar
dennis.pflug
Level 6
Great that you found a solution :)
