I wanted to create a pdf report of an analysis sent to my mail account.
Therefore, I created an action flow with the Celonis module "create PDF report".
To filter the analysis to get the correct data, I'm using a runtime variable which needs to be implemented in the action flow.
I implemented it as you can see on the first picture.
The result of the pdf report is, that it doesn't show me any data in my charts as you can see on the second pic.
Thanks for helping me.
Niklas
Hi Niklas,
Not sure if it is related, but you state 'DOMAIN' in your filter, is that necessary? I don't use it myself and cannot find documentation about us, so curious what is does (or break in this case).
Hi @niklas.meder ,
Is this issue got resolved. Please let me know what you have done. I'm getting same output in pdf report.
It will be very helpful if you provide it asap.
Regards,
Ajith.
