Is it possible to update different coloring pattern based on KPI Selection
  • September 26, 2023
  • 3 views
kailash.potha12
Level 5
Hello Developers,
I am using a dropdown option to select the KPI to display in the world map. My requirement is when i select 1st KPI 100% should be Red but when i select 2nd KPI 100% should be green.
Is it possible to update color pattern in this way, if yes could you share details.
Forum|alt.badge.img+5
Thanks for contacting us. We are aware that you already submitted a support ticket for this question. Please share the details of your expectations with screenshots in the support ticket. Thanks for your understanding.
