how do i display relative frequencies in the graphs?
Thanks in advance!
Cheers,
Olaf
Hi Olaf,
You can achieve this with an OLAP table, column chart etc by adding as a KPI being the frequency / total cases
If you elaborate a little bit further, I can propose you the exact formula.
Gabriel
Hi Olaf,
you can maybe leverage the prebuilt functionalities like in the screenshot below to create ratios. Is that what you mean by relative frequencies?
imageBest,
Kevin
