What all options do we have in celonis to export our analyzed process ? (ex - csv, excel, bpm)
hi Vijain, why would you like to export your process? and what exactly would you like to export? The data? Can you please share a screenshot?
I want to export the analysis (data) of the modeled process for some reporting work.
Now I see.
As far as I know you can export the data of an OLAP table as CSV or EXCEL but you should own the data model to do that.
okay, thanks @e.ndrio
Hi @e.ndrio,
How to export an OLAP table in excel? I use Snap and I dont see any button to do that.
Thanks
Hi @nico_eta
Step 1: You have to enable it in the analysis settings
image727317 16.8 KB
Step 2: right-click on the olap table and export
image804424 39.9 KB
Hi @e.ndrio,
It works fine! Thanks for the help!
Nico
@e.ndrio are there any other options to create a report or share information with others like pdf creation ? I am familiar with the share function but I was asked if I could send a pdf and others than doing screenshots and including these I dont know how I could do with Celonis Snap.
Hi @Jeanie no this is not possible within Celonis Snap.
@erin.ndrio11 is it possible to export Celonis data automatically to f.e. excel every day or week?
Hi there,
In an older post I saw that one can select the option 'Export to CSV/ Excel' in Analysis setting under 'general settings'.
I can't seem to find this option however. Can anyone explain to me where I can find it?
Dennis.
Celonis Question
