Celonis offers you a lot of features to share your success stories or achievements with other people. One of them is the so-called functionality Public link which allows you to share the published version of your analysis with this link.
  • First, navigate to Process Analytics
aaa11913935 256 KB
  • Click the dropdown menu of the analysis you want to share
  • Then public link
aaa21919931 74.7 KB
  • Click Enable public link
  • Click Copy to Clipboard
  • Click Save
  • Every person who has this link will be able to use (not edit) your analysis.
For example, this is my analysis that I share with you via this link:
https://snap-er-ndrio-gmail-com.eu-1.celonis.cloud/process-mining/public/df45b38a-46d2-4b4c-9ec2-4fc2293c15a8/#/frontend/documents/df45b38a-46d2-4b4c-9ec2-4fc2293c15a8/view
Is there any way to share an analysis path, so that the user gets redirected to a particular folder and find the analysis ?
Regards,
RJ
Thank you for asking. I think you can share any link as long as they have access rights to it.
Regards,
Erin
Hello Erin,
Can we have the Public Link that I shared with a Customer activated only till a specific future date. Post that date, I want nobody to view that analysis that i shared.
Thank You ,
Jayanta
Hi @Jayanta,
yes you can simply deactivate it. The same way you activated it. After that you link is not working anymore.
Hello Erin,
Just wanted to understand whether data export functionality is available for public links or not.
We are using Celonis C4C and have shared the public link to one of our customers, but they are not able to export data of an OLAP using the export functionality. It is giving an error
Any advice. Thank You in advance.
Warm Regards,
Jayanta
