How to analyze your Cash Preservation Process for SAP in Snap
The Cash Preservation Quickstart is the first step of your process mining journey with Celonis! With just a few clicks you can learn how to preserve cash within your processes. Simply export the relevant data from your SAP system to start your analysis.
In order to use this Quickstart you need to request the Cash Preservation SAP extractor first to export your data from you SAP.
This is applicable only for:
  • SAP ECC 6.0 or higher
  • S/4 Hana on-prem
How does it work?
  • First, navigate to SNAP
  • Then click the New Analysis button
1.11919970 174 KB
  • Click the title for Cash Preservation
2.11919970 128 KB
Extract data from your SAP system
In order to visualise your process, you first need to extract the relevant tables from your SAP system:
  1. Enter the company codes you want to analyse and request your Cash Preservation SAP extractor (ABAP report)
  2. You will receive an email with the Cash Preservation SAP extractor and a documentation on how to use it.
Note: ABAP reports are a proven way to extract data from SAP systems. Your IT department can support you with this step.
  • Click NEXT button
3.11918968 53.5 KB
Upload the extracted data to Celonis Snap
  • Click Select files to upload the tables you extracted in Step 1.
    The green check marks will tell you whether the upload was successful. After the upload, your event log and data model will be created automatically.
  • Click SUBMIT button
4.11920923 71.9 KB
Start discovering your End-to-End process
After completing 100%, you are ready to discover savings.
51919923 40.3 KB
Be the first to reply!
