Custom authentication method using the extractor builder for Data Integration (2024-08-19)
Related products:Data Ingestion & Infrastructure
  • Sep 5, 2024 11:18 AM UTC
  • 204 views
You can now configure a custom authentication method when creating a connection between your source system and the Celonis Platform using the extractor builder. The custom authentication type allows you to configure the authentication method based on your source system. This includes the following configurations:
  • Request (optional): Configure an API request to an authentication endpoint with all details (Request Type, Request URL, Headers, Parameters etc.)
  • Response (optional): Configure the location of an authentication token in the API response.
  • Authentication header: Configure how the response token is used in the authentication header for all endpoint request and add additional headers on top.
For more information about the extractor builder, see: Extractor builder. And for an overview of authentication methods, see: Extractor builder authentication methods.
The Custom Authentication wizard, where you can configure the request, the response, and the authentication header for endpoints.
