I'm trying to kick of a manual sensor skill by using the execute process automation skill. Running this skill than triggers the manual input that is required in the subskill. Has anyone gotten to make such a link working? I'm struggling with not knowing where the issue exactly lies, since the error message is extremely vague.
Problem running Nested Skills, does anyone have experience in triggering skills from another skill?
Best answer by rio.cinco12
Hi, you can follow the link below to do this. Create a skills and save it as an action where you can then use in the flow.
https://docs.celonis.com/en/save-skills-as-actions.html
Hope that helps,
Rio
