How to create an Array of all clerks to iterate through it with an action flow?
  • May 22, 2024 11:13 AM UTC
  • 253 views
jonas.venne
Level 2
Hi all,
i try to send a list of all open invoice to the responsible clerk.
So first of all. I want to query data to get all active clerks (by an Filter). But I can't create an array out of the query.
After I create the clerk array. I just itereate through it and do another data query with each iterator as filter. After that i send the list via mail.
But I am failing to create the array out of the query. Do you have any ideas how to handle that situation? I think I am using the wrong bricks.
Jonas Vennemann
matt.witty13
In the same grouping as Iterator, there's a module called "Array Aggregator". This will allow you to build an array and group it on specific fields as well.
