Payroll process mining
  • September 28, 2020
  • 4 views
Hello, has anyone had any experience in payroll process mining? The data is in Mepco software. I could not find any apps in the app store rather than recruitment process in HR. What I am interested in is mining the payroll process of HR from Mepco. Thanks
Hi @sezin.yaman12,
unfortunately there is no standard connector that you could leverage. In general, I would recommend to check the EMS store. All available process connectors are shared there.
Justin
