How modify the maximum execution timesout in Action Flow ?
  • August 8, 2023
  • 1 view
Hello guys,
I'm trying to find a solution to modify the maximum execution timesout in one of my Action Flow, it stops before all data are transfer in one of my google sheet file.
Do you have an idea ?
Thanks !
Hi Antoine,
Thank you for reaching to us.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description.
We will gladly help you.
Thank you in advance.
BR.
