 How is it posible to use WORKDAY_CALENDAR and WORKDAY_CALENDAR without problems.
 How is it posible to use WORKDAY_CALENDAR and WORKDAY_CALENDAR without problems.? I want to use both calendars at the same time.
I have use INTERSECT, and i have join both calendars adding the id_calendar to the tables, but i get always the same error.
Error in formula
To use the calendar ID column [constant SP-MAD], it must have a join relationship to the table containing the timestamp column ["IssuesFunes"].
The formula is the following.
REMAP_TIMESTAMPS (
   "IssuesFunes"."created" ,
    HOURS ,
    INTERSECT ( WORKDAY_CALENDAR ("WDCalendar") , WORKDAY_CALENDAR( "WORKDAY_CAL_TFACS" ) ) ,
  'SP-MAD'
Hello Enrique.
Yes, possible to use together. In the documentation, we see an example using the same functions twice, inside an "Intersect".
https://help.celonis.cloud/help/display/CIBC/INTERSECT
Looks like the error is not related to the intersect/calendars , but to the relationship between tables (calendars and the table with the timestamp)
Tks. D
Hola Daniel,
Thanks, i will check it.
