Good afternoon/Good morning Celonautas, could any of you tell me if there is any way I can clear the variable? For example, the variable is disabled. I would like it to clear the variable from my dropdown when it is selected.
Here is how it looks when I disable it.
And how I would like it to look
Maybe possible with a skill if your Dropdown is a real Variable and not like VBAP.VBELN.
Then you can say to the skill, if status is deactivated then variable x = ‘ ’
