If a client has already designed their TO-BE business processes, is it possible to ingest their data into their designed TO-BE processes, in order to confirm/simulate how the processes would perform before being implements?
Hi @mpho.mathe,
You could do two things:
  • If their to-be process is in the BPMN notation, you could use the Conformance Checker (celonis.com). In this case, you can see to which regard the current process is following their To-be standards
  • If their to-be process is almost the same as their current process, you could use Process Simulation to make a digital twin of the process. Next you will create a scenario where the process branches are changes as in the to-be situation (see Branches (celonis.com)). You should now be able to see the expected process behavior after applying the changes.
For both solutions there are courses available in the Celonis Academy.
Hi @mpho.mathe,
Thank you!
Thank you!
You’re welcome!
Please mark this question as answered by accepting the solution, to help fellow Celopeers.
