Can anyone suggest the pql formula for that..?
for the 3rd column you can make use of one of those DateTime Difference Functions: DateTime Difference (celonis.com)
e.g like DAYS_BETWEEN or DATEDIFF
And you KPI can be calculated like this:
AVG(DAYS_BETWEEN(
PU_FIRST(CASE_TABLE, TABLE.COLUMN1),
PU_LAST(CASE_TABLE, TABLE.COLUMN2)
BR
Dennis
AVG(DAYS_BETWEEN(
BR
Dennis
Hi Dennis,
Both timestamps are in case table then the formula which you suggested will not work right.
is there any other formula for that..?
Ok in this case I would try to make use of an DOMAIN_TABLE: DOMAIN_TABLE (celonis.com)
e.g:
AVG(DAYS_BETWEEN(
PU_FIRST(DOMAIN_TABLE(CASE_TABLE._CASE_KEY), CASE_TABLE.COLUMN1),
PU_LAST(DOMAIN_TABLE(CASE_TABLE._CASE_KEY), CASE_TABLE.COLUMN2)
BR
Dennis
e.g:
AVG(DAYS_BETWEEN(
BR
Dennis
Hi Dennis,
The use of DOMAIN_TABLE has worked to solve that.
Thank you so much for your time.
Hi Dennis,
You're welcome. :)
