How to implement conformance checker with own process flow
We have lack of knowladge . We would like to load a process flow like this.
Lets assume we have process Flow like that A-> B-> B->C-B->B-> D->B->B->E
When we do conformance I would like to use A->ANY To ANY -> C Any to Any ->D Any to Any->E
I mean Any activity between A->C could be exits.
Vahide.
  • Level 3
  • April 13, 2022
Hi @vahide.öztür ,
I would suggest you to upload a BPMN model to your conformance sheet.
A >> Use Event Based Gateway (specify all events) >>C >>Use Event Based Gateway (specify all events)>>D>>Use Event Based Gateway (specify all events)>>E
Regards,
JayB
Hi JayB,
Thank you very much for your reply.
Could you please explain me which type of item is "Use Event Based Gateway" from following ones ? And how can I specify all events ?
Vahide.
I found how to specify eventbase gateway,
only question is how can I specify all events ?
Could you please support ?
Vahide.
z.b wrote:
Hi @vahide.öztür ,
Regards,
JayB
image" data-fileid="06907000007UeYQAA0
  • Level 3
  • April 18, 2022
Hi @vahide.öztür ,
Can you please try to implement the BPMN as attached. Hopefully it should work.
Regards,
JayB
