Hi, How can I "hide" a published package inside a space? Just like i can hide (Visibility On/Off) the assets inside a package, i was looking for a solution for hiding the whole package. thanks
Forum|alt.badge.img+14
Best answer by kailash.potha12
Hi Himanshu,
If you hid the package visibility and publish then it won't be visible in apps
  • June 21, 2023
Hi Himanshu,
i faced the same problem, but at the end i created a new Space with the name Archived for example and moved all my packages that I don't use often to that Space
Hi Rashid,
ja seems that's the best workaround. Thanks for the answer :)
cheers
  • June 21, 2023
you are welcome! cheers
kailash.potha12
Level 5
Hi Himanshu,
kailash.potha12 wrote:
Hi Himanshu,
Hi Kailash,
how did i miss that 😆 . Thank a ton for pointing that out.
cheers
  • June 22, 2023
Hi Himanshu,
HI Himanshu and Kailash,
this is very useful from the apps perspective and thank you Kailash for pointing that out :)
Himanshu my Solution is only for Studio Perspective, it is useful when you as Analyst don't want to be involved in a specific Projects anymore. I had this situation once.
kailash.potha12
Level 5
himanshu.sharm16 wrote:
Hi Kailash,
cheers
When We involved too much in the topic we miss small things. 😜
