Total throughput time of a sub process which occurs multiple times within a case
  • Mar 19, 2022 9:32 PM UTC
  • 69 views
Good evening guys,
I would like to calculate the total throughput time of a sub process which can occur multiple times within one case. The subprocess always starts with a unique activity and ends with a unique activity. There might be different activities between the start & end activity (see picture).
imageI tried my best by using the MATCH_PROCESS_REGEX function but didn't succeed.
Thanks a lot for any hints and suggestions!
Cheers,
Alex
It's rather complicated problem, so for now i will just advice with general approach - maybe in some days I will create practical example with solution.
  1. You can use REMAP_VALUES to NULLify all the activities besides B & C, which will leave you with possibility to use DAYS_BETWEEN(<eventtime>, LEAD(eventtime)) functions to calculate times between rows.
  2. After calculation you would need to use PU_SUM(Case_table, earlier PQL calculation statement)
I think it's good place to start, but unfortunately it will calculate time difference for every row, and you want to have calulation only for B's
Mateusz Dudek
