we are looking for an option to restrict the dropdown of an “Asignee” component to a selected number of persons. Currently the dropdown shows ALL persons / groups in our tenant (see example below):
Is it possible to restrict the dropdown to display only pre-defined users or user groups? If so, how can this be achieved?
BR,
Sorry, where is this dropdown? Is this in a view, or action flow?
It´s in a view - triggering a action via a skill.
Hi ​@nicolas.kazek,
Tasks can now be management using the ‘Task Management’ function, replacing the setup of Skills.
Here you can specify the scope of the task who can see and act upon it:
More about the new Task Management can be found on the docs: https://docs.celonis.com/en/tasks.html
