Open SAP GUI from Views?
Hi, I would like to open SAP GUI on clicking from Views(OLAP Table) where it gets redirected on clicking a VBELN from the OLAP Table goes to the corresponding transaction in SAP. Similar to below screenshot from Analysis:
imageCurrently it is possible using Action Engine- Action feature like below screenshot:
image.pngKindly let me know if there's a possibility in Views.
Thanks!
@shravya.b11​
marco.marso
Level 3
You edit the table and add it as On Click Action, just define an attribute in the KM first:
When using Studio, this is possible via the field "Allow Data Service Link".
You can use the column of the VBELN as variable:
BR,
Marco
Hello @marco.marso ,
Thanks for your response .This approach works :)
