How to split the value in a particular column into columns? Need help with this query.
  • Sep 17, 2022 3:47 AM UTC
  • 6 replies
  • 162 views
Eg: for a column "NAME" one of the value is "HELLO-WELCOMETO-CELONIS"
I want this to be split to 3 columns..
Intro: HELLO
Greeting: WELCOMETO
Tool: CELONIS​
As 3 different columns
CHARINDEX giving error that this function does not support. ​
  • Sep 19, 2022 6:05 AM UTC
STRING_SPLIT
https://docs.celonis.com/en/string_split.html
Intro = STRING_SPLIT("NAME",'-',0)
HTH
sarina.somme
Level 5
Forum|alt.badge.img+11
When I want to use the function STRING_SPLIT I get the following error:
Execution error: Function STRING_SPLIT is not supported
Does anyone know what could be the reason for this?
  • Oct 13, 2022 12:02 PM UTC
Hmmm, is the column of type string? Otherwise should be some bug, because STRING_SPLIT is still in the documentation
sarina.somme
Level 5
Yes the column is VARCHAR(100), so this shouldn't be a problem. I also wonder why I get this error, because I had taken this function from the documentation.
sarina.somme
Level 5
I used the Function SPLIT_PART from the Vertica documentation and now it's working.
  • Oct 13, 2022 1:47 PM UTC
