How to download a zip file from ML Workbench directory?
  • October 22, 2024
  • 41 views
miguel.ferna11
Level 3
I have generated a zip file with the content-cli module and now I need to download it locally, but every time I press the “Download” button it creates an HTML file. That HTML redirects me to a “Secure download” which re-downloads the same HTML.
How can I avoid the HTML and just retrieve the zip file?
florian.mrkvi
Level 4
Hi Miguel!
This is on purpose. Just open the HTML file and click on “Download file”.
Additionally you can check the checkbox “Don’t show this again”, then you will get the file without the HTML step in between in the future.
Hope this helps,
br Florian
mateusz.dudek14
Level 7
Forum|alt.badge.img+11
I think @florian.mrkvi  provided valid solution but I’ve got one question - do you maybe know how to disable that technically for even user that didn’t clicked it? I was using that in combination with Iframe, and instead of showing HTML file, users see nothing unless they will go for file itself, download the security html and not forget to click on checkbox - do i need to create artificial cookie? :)
Mateusz Dudek
