How can i build an action flow that does something if Data in Celonis changes?
Use skills, and the one of the Celonis sensor, as a next step in Skill, you can then execute the action flow.
For example, you can trigger your skill via Action Engine, and Action Engine can trigger it based on a data change.
Hope this helps.
Hope this helps.
Thanks for the answer. So its not possible to do this with just an action flow?
