Format Field vs. Format Function
  • Jan 21, 2022 3:42 PM UTC
  • 45 views
Forum|alt.badge.img+7
Why is the format field in the pql-editor offering more options in formatting the output than the FORMAT() function? E.g. I can enter in the format field in the pql-editor the format '%d.%m.%y' without any occuring errors but not in the format function while converting a date to a string.
Format FunctionFormat Field
Forum|alt.badge.img+2
Hello Franziska,
Unfortunately it seems that the 2 digit year %y is not currently supported by the FORMAT() function. If a 4 digit year is fine for you, please try this format: '%d.%m.%Y'
If you need a 2 digit year, try this PQL:
TO_STRING("FOCUS_INSTANCES"."AS_OF_DATE", FORMAT('%d.%m.')) || RIGHT(TO_STRING(YEAR("FOCUS_INSTANCES"."AS_OF_DATE"),2)
