Basic sql behaviour, getting cases with changes in NETPR
  • Nov 3, 2021 11:00 AM UTC
  • 8 replies
  • 145 views
Hi there,
I am getting this strange behaviour and was wondering if somebody can explain this?
I want to create an activity for when NETPR in CDPOS changed to 0 but when I look for 0s the table is empty.
Query 1: My first entry happens to be a case that I am looking for.
   SELECT DISTINCT FNAME,VALUE_NEW from CDPOS
   WHERE FNAME = 'NETPR'
   ORDER BY VALUE_NEW
   LIMIT 1
   FNAME  VALUE_NEW
   NETPR  0.00
Query 2: But I get an empty table when I use these conditions.
   FROM CDPOS
   WHERE FNAME = 'NETPR' AND VALUE_NEW = '0.00'
   FNAME  VALUE_NEW
Next I wanted to see if my VALUE_NEW = '0.00' might be wrong somehow.
Why do I get different smallest values '0.000' and '0.00' from query 3 and query 4 respectively?
Query 3
  SELECT DISTINCT VALUE_NEW from CDPOS
  ORDER BY VALUE_NEW
    VALUE_NEW
    0.000
    1.000
Query 4
  SELECT DISTINCT FNAME, VALUE_NEW
  FROM CDPOS
  ORDER BY VALUE_NEW
   FNAME  VALUE_NEW
   NETPR  0.00
   NETPR  0.01
   NETPR  0.01-
Query 5: Looking for multiple strings with 0 get's me an empty table again.
  FROM CDPOS
  WHERE FNAME = 'NETPR' AND VALUE_NEW IN ('0','0.0','0.00','0.000')
  ORDER BY VALUE_NEW
  FNAME  VALUE_NEW
Best answer by stephane.multo
Hi Sasa,
The leading spaces are reassuring as they seem to explain all these query results.
It seems all your query results make sense actually, given that the VALUE_NEW have leading spaces.
In short what's to remember is it might be better to use the TRIM(VALUE_NEW) everywhere in your related queries, to avoid confusion and empty results.
So most of query 6 looks good, you should just use TRIM(VALUE_NEW) in the WHERE clause as well:
SELECT DISTINCT FNAME, TRIM(VALUE_NEW) AS VALUE_NEW
FROM CDPOS
WHERE TRIM(VALUE_NEW) = '0.00'
This could likely work.
Hi Sasa,
Here are a couple ideas:
  • It might help to try querying CDPOS with a float filter for VALUE_NEW (e.g. WHERE VALUE_NEW = 0.0) instead of a string filter. VALUE_NEW is indeed usually a string but never know.
  • There might be non-displayed empty characters before/after the 0 values, such as non-displayed spaces. You could try to SELECT '|' || VALUE_NEW || '|' to see if there are invisible spaces around the 0 values which are preventing the 0 filters from finding the data.
  • Nov 5, 2021 9:36 AM UTC
Hi Stephane,
thank you for your suggestions. I tried a couple of things but I am none the wiser and still puzzled.
Especially Queries 4-6 make no sense to me. I must be making a logical mistake here but I can't figure it out.
I tried your suggestion with the pipes.
Query 1
SELECT DISTINCT FNAME, '|' || VALUE_NEW || '|' as VALUE_NEW
FROM CDPOS
ORDER BY VALUE_NEW
FNAME VALUE_NEW
NETPR | 0.00|
NETPR | 0.01-|
NETPR | 0.01|
And it looks like VALUE_NEW has a leading space.
However, I get the same result when I try to remove it wit trim.
Query 2
SELECT DISTINCT FNAME, TRIM('|' || VALUE_NEW || '|') as VALUE_NEW
FROM CDPOS
ORDER BY VALUE_NEW
FNAME VALUE_NEW
NETPR | 0.00|
NETPR | 0.01-|
NETPR | 0.01|
NETPR | 0.02-|
NETPR | 0.02|
NETPR | 0.03-|
When I use Trim without the pipes I get a similar result but the ordering is different.
(No idea how celonis sorts these strings.)
Query 3
FROM CDPOS
ORDER BY VALUE_NEW
FNAME VALUE_NEW
NETPR 0.00
NETPR 0.01
NETPR 0.01-
NETPR 0.02
NETPR 0.02-
NETPR 0.03
Next I wanted to see how my conditions work if I only use the first row of my table.
I get an empty table when I use VALUE_NEW without trimming
Query 4: VALUE_NEW not trimmed.
SELECT * FROM
(SELECT DISTINCT FNAME, VALUE_NEW
FROM CDPOS
ORDER BY VALUE_NEW
LIMIT 1) as TMP
WHERE VALUE_NEW = '0.00'
FNAME VALUE_NEW
--empty
It works when I use the trimmed version and a subquery
Query 5: VALUE_NEW not trimmed.
SELECT * FROM
(SELECT DISTINCT FNAME, TRIM(VALUE_NEW) AS VALUE_NEW
FROM CDPOS
ORDER BY VALUE_NEW
LIMIT 1) as TMP
FNAME VALUE_NEW
NETPR 0.00
But not without the subquery
Query 6
FROM CDPOS
FNAME VALUE_NEW
--Empty Table
  • Nov 5, 2021 9:52 AM UTC
Sorry, Query 5: VALUE_NEW not trimmed should read Query 5: VALUE_NEW trimmed.
Hi Sasa,
FROM CDPOS
  • Nov 9, 2021 8:16 AM UTC
Hi Stephane,
that did it. Thank you !
  • Nov 12, 2021 9:09 AM UTC
Hi Stephane,
is there a way to use TRIM in the table configuration during the extraction? I found more columns that are full of trailing and leading spaces. If this is not possible, what would be the best practice? We are trying to avoid additional TMP tables.
Hi Sasa,
I believe it isn't possible to use TRIM within the extractions. However I'm not sure this should lead to more TMP tables.
For example, if you extract EKPO or VBAP and you have leading spaces, you would just pull the TRIM columns at the same time you are creating the DM version of those tables (P2P_EKPO or O2C_VBAP):
CREATE O2C_VBAP AS (
SELECT VBAP.*, TRIM(column)
FROM VBAP
As for CDPOS, one usual method would be to pull the TRIM columns into TMP_CDHDR_CDPOS which is the standard pre-join between CDHDR and CDPOS at the beginning of the Data Job. Then you can use that TMP table and its TRIM columns in any subsequent transformation.
  • Nov 12, 2021 4:17 PM UTC
Hi Sasa,
FROM VBAP
Yes, you are right we could do it at TMP_CDHDR_CDPOS. I just went trough code where my predecessor used CDPOS instead of TMP_CDHDR_CDPOS. I need to investigate this further but thank you for your help!
