Top Header
id like to create a skill which is triggered on every first of the Month. I Created an kpi like this if Left(Today(),2) = ‘01’ then KPI = 1. So my KPI logic is working fine but, i do not found any way to use this kpi as a trigger for a Smart Sensor. I included the KPI into a Record, but when i try to use this record in smart sensor, it does not show me created attribut with my KPI.
Did anyone had a similiar Projekt with triggering Smart Sensor at the first of the Month, and could maybe help me?
Kind Regards Jonas
Be the first to reply!
