For example, as shown below, when you click a data field, a popup with choices should have appeared automatically.
However, I get an empty popup from today's morning (JST 9:00).
Could you tell me why this happened?
Yours,
Chen
Yours,
Chen
Best answer by janpeter.van.d
Hi @claire.chen12,
Did you see values in this field before? If yes, it might be a temporal failure and you could report it using a service request (I don't think they monitor the Celopeer Posts).
If not, be sure that you connect the previous nodes with the required data format so that it will pop-up here.
