Using SUBSTRING during Extraction SAP ECC
  • Dec 3, 2020 12:53 PM UTC
  • 94 views
Hi there, we are currently in the middle of the extraction of a production planning process from our SAP ECC. Now there is the need to extract only certain lines of the CDHDR and CDPOS. We know that a join is theoretically possible between AUFK.AUFNR and CDHDR/CDPOS.OBJECTID. To make it an exact join, though, one has to extract a substring of the OBJECTID, as the AUFNR is only a part of the OBJECTID. We tried this: SUBSTRING (CDHDR.OBJECTID,6,12) = AUFK.AUFNR. It returned an error, though. Does anybody know, where the problem is or is there a better solution to our problem? Happy for any help and best regards, Carl
  • Level 0
  • Nov 22, 2021 3:30 PM UTC
Hi @carl.schad,
in case this error still occurs, I would suggest reaching out to our Servicedesk to find a solution. Without further information, it is difficult to find a solution.
Kevin
gabriel.okaba11
Hi Carl,
you can't transform on the extraction join.
You can achieve similar results by applying a filter on CDPOS.TABNAME = 'AUFK' and joining with CDHDR during extraction.
Let me know if you need any further support
Gabriel
