Using PU_STRING_AGG as an input for the IN operator
  • Dec 16, 2021 6:58 PM UTC
  • 94 views
Is it possible to use the PU_STRING_AGG function as an input to the IN operator?
Here's the snippet I'm trying to get to work:
CASE WHEN
LIPS.POSNR IN ( ' \\'' || PU_STRING_AGG(LIKP, LIPS.UECHA, '\\',\\'' ) || '\\'')
THEN 'Y'
ELSE NULL
Not very clear as to how the PU_STRING_AGG handles the values - does it wrap the whole string with an additional set of start/end single quotes? If so - will the single quote delimiter along with a comma turn the string into a list of strings?
  • Celonaut
  • Dec 23, 2021 3:49 PM UTC
Hi Eugene,
It is possible to use PU_STRING_AGG as input in an IN operator.
I have tried the following code snippet in an OLAP table KPI:
CASE WHEN
PU_STRING_AGG ( table, column, '-' ) IN (PU_STRING_AGG ( table, column, '-' ))
THEN 1 ELSE 0 END
And it returns successfully 1 for every row.
The function operates similar to a CONCAT function, it does not wrap with additional set of single quotes.
I would recommend looking at help.celonis.cloud/help/display/CIBC/PU_STRING_AGG for further reference about how the function works and examples.
Hope this helps you with your question.
Best regards
