PQL compare dates on activity level
Hi @janpeter.van.d​ / @Celopeers .​
I'm trying to compare two dates from different columns in order to find out about a delay.
For this I need to
(1) compare the highlighted dates in the red box
(2) if the ETA is earlier than the Timestamp of the Activity "Ready for Pickup" I need to mark it with the value "1" in the respective column and line (as highlighted)
[Note that the columns "ETA" and "Delay" are two manually created attributes within Celonis and were not part of the extracted data.]
I guess I need to use a PU function here, but as I'm not very familiar with it I'd very much appreciate any help.
Thanks in advance anf brgds, Finn
I actually have the same problem! :)
janpeter.van.d
Level 8
Forum|alt.badge.img+19
Hi @1461001156,
In the column Delay, you could put something like this:
CASE
WHEN
-- get the difference of two timestamps
DATEDIFF(
-- select datediff granularity (here in milliseconds)
ms,
-- select timestamp column
<table_name>."Timestamp" ,
-- select ETA timestamp of first 'Order Received' Activity
PU_FIRST(
-- set the first column as case reference domain, i.e. the PU-function uses this column
-- to select the rows that should be compaired.
DOMAIN_TABLE(<table_name>."Case_ID"),
-- select column of which the first timestamp should be taken
<table_name>."ETA",
-- set filter to only use the order received row
Activity = 'Order received'
) > 0 -- select if datediff should be higher or lower than zero
THEN 1.0
ELSE 0.0
Hope that this works for you!
janpeter.van.d
Level 8
janpeter.van.d wrote:
Hi @1461001156,
CASE
WHEN
DATEDIFF(
ms,
PU_FIRST(
<table_name>."ETA",
THEN 1.0
ELSE 0.0
See that the markup is deleted, sorry for that!
Hi @janpeter.van.d , thanks so much for your detailed answer! I guess this could work, however, it says that column "ETA" can't be found (I guess it's because "ETA" is a column which I manually created as an attribute). Is there a way how I can make the column visibile (e.g. changing a setting in the attribute)...?
Hi @1461001156,
CASE
WHEN
DATEDIFF(
ms,
PU_FIRST(
<table_name>."ETA",
THEN 1.0
ELSE 0.0
As you can see in the Screenshot, the column is somehow unknown (I created it as an attribute). Do you know a way how i can make it visible?
Forum|alt.badge.img+13
@1461001156
What are you using to define ETA as an attribute?
If you used a PQL expression to create it, simply replace your <table_name>."ETA" with the PQL expression you used to create the ETA attribute in the PU function, and it should work.
Separately, when using PU_FIRST I would definitely recommend using ORDER BY expression to make sure you are truly pulling the first value. Alternatively, you can use PU_MIN, in that case it will pick up the earliest timestamp regardless of order in the underlying table.
Eugene
janpeter.van.d
Level 8
Hi @1461001156,
See the answer of @Eugene Em below. Hopefully that works!
