Mapping of Celonis Activities with SAP activities
Forum|alt.badge.img+7
Can anyone has this mapping information?
I would like to see the list that shows the mapping of Celonis activities (eg: AP process) to SAP tables.
Like while calculating the clear invoice steps which tables, timestamps are used in SAP. Similarly for other activities. This will be a good reference document to begin with and help to customize the activities in Celonis if we need to do so.
Appreciate your inputs here.
Hi @madhava.pemma,
this is unfortunately not included in the standard process connectors. As one activity can combine data from several tables, I would recommend to go through the activities and check which table is most appropriate. I would add them then in a several column in the activity table.
If you have further questions on how to set this up, just let us know!
Justin
Adam Smith
Level 2
Hi ​@madhava.pemma,
I just saw your post. What we are doing to create custom activities that are not provided by the standard process connectors is search for DATS Datatype fields in the SAP Table reference. Since you need some sort of date for an activity. If you found the relevant date, then you build up the joins to create the activity. A good source for table information for SAP tables is ERPExplorer.
If you have further questions on how to derive activities, don’t hesitate to reach out.
Adam
