How do I use PU_FIRST and PU_LAST function to calculate the total wait time between my operations?
I have cases table with _CASE_KEY and OPERATION NUMBER. Each _CASE_KEY can have N operations. For ex:
_CASE_KEY: 01000200
  1. OPERATION 0001
  2. OPERATION 0100
  3. OPERATION 0500
  4. OPERATION 0700 (etc)
_CASE_KEY: 03000200
  1. OPERATION 0001
  2. OPERATION 0100
  3. OPERATION 0500
The goal is to calculate the time it takes from last operation of a case to first operation of the next case. In the example above, it would be time difference between the _CASE_KEY 01000200, OPERATION 0700 to _CASE_KEY 03000200, OPERATION 0001. I am trying to use the PU_FIRST and PU_LAST to accomplish this goal but unfortunately it is NOT giving me what I am looking for. Any help would be appreciated. I do have the ACTIVITIES table where all of these operations that I've mentioned above are shown.
Are operations modeled as Activities?
Hi Yes, the operations are incorporated to form the activities. Giving the Above example
_CASE_KEY: 01000200
  • OPERATION 0001
  1. ACTIVITY 1 [0001] - Create
    1. ACTIVITY 2 [0001] - Modify
    2. ACTIVITY 3 [0001] - Delete
  • OPERATION 0100
The same structure gets repeated for all of the CASES and each case can have N operations.
Ok... here the main problem is to define "next" case... as we expect the cases are not sequential.
But let's imagine you have a way to know which is the next case.
To know the first activity of a case you can use INDEX_ACTIVITY_ORDER and look for the one with 1
https://docs.celonis.com/en/index_activity_order.html
The last one is more tricky.... you can use INDEX_ACTIVITY_ORDER combined with count_table(activity_table) to know how many activities has a case, then search for the activity with INDEX_ACTIVITY_ORDER.
Also you can use PU_MAX(CASE_TABLE, ACTIVITY_TABLE.EVENTTIME) to get the last activity per case.
Also INDEX_ORDER can help
https://docs.celonis.com/en/index_order.html
Maybe combining the above ideas you can get what you want. A lot depends on, for starters, how to identify the "next" case. And if you need this as a single KPI, combined in a OLAP table, etc....
HTH
Hi @Guillermo Gost , I was able to get what I wanted using the Source and Target. Thank you for your help!
