Hi, can anyone please help me with a PQL query.
  • October 31, 2023
  • 2 views
I am trying to extract the date from a string. the date comes after '-'. The challenge is that there can be more than one instance of '- '.So, tried to find the '-'followed by a space and '/'after 3character
String sample: $$$$$ $$$$$$$: $$~$$$$ - $$$$ $$$$$$$$ $$$ $$$ ~$$$$ $$$$$$$$ $$/$$/$$$$ - 07/01/2022 $$$:$ $$$:$ $$$:$.$ ( i want to extract the date after the second '- ')
Code I used:(code gives me error)
CASE WHEN
MATCH_PROCESS_REGEX ( column, '.*- .{3,}/' )=1
THEN TO_DATE(RTRIM(RIGHT(STRING_SPLIT (column, '- ' , 0),11)),FORMAT ( '%d/%m/%Y'))
ELSE NULL
Thanks In Advance
Hmmm... if there is several instances of '-' but only one date, then maybe you should try to match '-" followed by a date...
testing in Regexpal, this pattern ' - (\\d\\d/\\d\\d/\\d\\d\\d\\d)' will match
HTH
