Studio: Case Explorer - display, sort, and search cases (2023-07-14)
  • August 9, 2023
  • 102 views
The new Case Explorer component lists cases with the number of activities, first and last activity and their timestamps, and throughput time. You can display any extra columns that you have in your case tables. Select a case ID to see searchable details of all the activities.
You can add Case Explorer to views in Studio, and Business Miner uses it when you view a specific case. Case Explorer supports multiple event logs - you can define which is the main event log. See Case Explorer for the documentation.
Forum|alt.badge.img+12
Great!
BTW the right link for the documentation is https://docs.celonis.com/en/case-explorer-views
carlos.taleg11
Level 9
Forum|alt.badge.img+10
Thank you
