Top Header
Is there a way to filter the process explorer based on the selection made on the execution-gaps object or to get the current filter on the view to set the filter for the process explorer.
  • June 23, 2021
  • 21 views
In this particular case I want to select one of the flags and the selection will filter the process explorer for some activitiesCapture
Hi Eleonora,
yes, in the Knowledge model you can determine a filter condition for each Execution gap.
imagethis can then be passed inside views to filter components even entire Profile Viewsimage.pngSo when you click on the Execution Gap, the Profile View that then opens up will be filtered based on what you determined in the filter statement. All you need to do is to add the process explorer component to the view that opens up.
