How can I create a PDF report from Studio Skill for my analysis in the Studio
I try to create this skill in the Studio, in the sheet section( I marked it in the screenshot) there are no options for my sheets of analyses that’s why I cannot selected any.
celo
Even if I have 3 sheets in my analysis (called “deneme”), I cannot selected these in my skill settings. How can I select these?
celo2
Have you published the analysis you are trying to reference? Also, do you have full permissions?
Yes I have published. Also, I have full permission for my application key that used in my skill, did you mean that kind of permission or another else?
I solved missing sheets problem but I encountered an error like in the screenshot. pdf-error
Hi Ugurcan,
the application key needs USE Permissions on the analysis you want to create the PDF for. Can you maybe share the configuration of this module so we can support you.
Kevin
