Hi all, is it possible to make a dimension in a OLAP table static. So when I click on another dimension it does not affect the value?
koert.kritz11
Level 3
Sverre Klein
Level 6
Forum|alt.badge.img+14
Hi @koert.kritz11,
When you want to keep an OLAP table static with its dimensions, you can tick the "component not filtered with selections" option (in an analysis).
Hopefully this is what you are looking for!
Sverre Klein
kailash.potha12
Level 5
sverre.klein11 wrote:
Hi @koert.kritz11,
Sverre Klein
HI @sverre.klein11 - Do we have similar option in views..?
Sverre Klein
Level 6
Hi @kailash.potha12,
Yes that is possible through YAML in views!
You have to use the interactions key under settings, and then set the field filteredByUserFilters on false.
renditionDownloadKind regards,
Sverre Klein
kailash.potha12
Level 5
Thanks it is working πŸ‘
Sverre Klein
Level 6
Hi @koert.kritz11,
I hope you were able to solve your issue? Let us know! 😁
koert.kritz11
Level 3
Hi @koert.kritz11,
Yes I was, Thank you!
