I know, this question seems odd at first. I finished modelling and I have big transparency on the process now. I can start analysing using the dashboard. Its just - where to begin?
  • Do I check for Cases, that are not happy path?
  • Do I start improving the happy path runtime by looking for bottlenecks?
  • Should I check which variables influence the propability for the instance to flow in the happy path?
I know - generally Process Mining seems to be about discovery. Howevery I want to spend my time efficiently, so I am looking for best Practices, frameworks etc.
Am happy for responses and ideas. :-)
Hi Timon,
Thanks for reaching out to us!
We would recommend checking the help page regarding the analysis https://docs.celonis.com/en/process-analytics.html and also checking the Celonis Academy Courses like: https://academy.celonis.com/learn/learning-path/build-analyses-basics.
Many thanks for your understanding.
