Process Minning for Office 365 tools
  • March 3, 2023
  • 16 views
andré.tafur
Level 8
Forum|alt.badge.img+15
Hi Celopeers,
Currently, we are facing the challenge of being able to extract metadata from excel, word, PPT files in order to mine the general activities performed in these applications and include them in an eventlog, for example the activities: open document, update document. For the moment we do not want to go to the level of detail of knowing what was done specifically in the document (which would mean a task mining use case).
With this premise, I would like to ask you if you have had a similar case and what would be the best method to extract this metadata and generate the eventlog?
Thanks everyone!
Actualmente, estamos enfrentando el reto de poder extraer los metadatos de archivos excel, word, PPT para poder minar las actividades generales que se realizan en estas aplicaciones e incluirlas en un eventlog, por ejemplo las actividades: abrir documento, actualizar documento. Por el momento no queremos llegar al nivel de detalle de saber qué se hizo específicamente en el documento (lo que significaría un caso de uso task mining).
Con esta premisa, quisiera consultarles si ¿han tenido un caso similar? y ¿cual sería el mejor método para extraer esta metadata y poder generar el eventlog?
¡Gracias por su ayuda!
http://www.DeepL.com/Translator
  • Level 0
  • March 18, 2023
Hi André, Many thanks for reaching out. Could you please open a ticket through Celopeers and provide us the details of the use case? Best regards,
