I need help in building a KPI using two columns, I'm trying to build the KPI but the code is not getting executed for all the rows i.e. the 2nd condition code is not getting excecuted i'm getting the o/p as Blank .
Requirement:
Below is my code:
CASE WHEN ("CONTROLLER_xlsx_Sheet1"."KEY") = '10' AND COALESCE ("CONTROLLER_xlsx_Sheet1"."CONTR", 'RANDOM_VALUE') != 'A50' OR
("CONTROLLER_xlsx_Sheet1"."KEY") IS NULL AND ("CONTROLLER_xlsx_Sheet1"."CONTR") NOT IN ('A01', 'A02', 'A03') OR
(ISNULL ("CONTROLLER_xlsx_Sheet1"."CONTR") = 1 )THEN 'CLEANSE' ELSE 'PERFECT' END
Hi @Gundappa Pujari,
I think you can improve your code in two ways:
  1. Use brackets to show AND/OR groups
  2. You use two ways for dealing with null values (see marked places), use here the ISNULL() operator
CASE
WHEN (("CONTROLLER_xlsx_Sheet1"."KEY") = '10' AND COALESCE("CONTROLLER_xlsx_Sheet1"."CONTR", 'RANDOM_VALUE') != 'A50')
OR (ISNULL ("CONTROLLER_xlsx_Sheet1"."KEY") = 1 AND "CONTROLLER_xlsx_Sheet1"."CONTR" NOT IN ('A01', 'A02', 'A03'))
OR (ISNULL ("CONTROLLER_xlsx_Sheet1"."CONTR") = 1)
THEN 'CLEANSE'
ELSE 'PERFECT'
I hope this helps.
CASE
THEN 'CLEANSE'
ELSE 'PERFECT'
I hope this helps.
Hello @janpeter.van.d ,
Thank you for the suggestion. I tried adding the brackets but still 2nd line code is throwing blank output.
Gundappa
Hi @Gundappa Pujari ,
I think the problem is the first check. Try the following:
CASE WHEN COALESCE("CONTROLLER_xlsx_Sheet1"."KEY", '-') = '10' AND COALESCE ("CONTROLLER_xlsx_Sheet1"."CONTR", 'RANDOM_VALUE') != 'A50' OR
THANK YOU @Daniel Diers  for the help 😊
Did this solve the issue @Gundappa Pujari ?
Hello Joos,
Yes, the above code solved my issue :)
