I want to benchmark/compare based on vendor, country and city. Is there any way I can get that in a single bitton dropdown instead of using 3 different button dropdowns.
I want to achieve this in cascade, like if I select vendor I should see the option to select country and city values.
Thank you​
Hi P.,
Yes this should be possible by adding the different columns within one button dropdown and seperate them by ||.
So for instance in your case you would have to write something like this:
TABLE1.VENDOR || ' ' || TABLE1.COUNTRY || ' ' || TABLE1.CITY
I hope this helped!
Hi @Preethi P was the above answer helpful for you? Thank you.
Hi, unfortunately No. As the above code will not work as a cascade. It will only concatenate the result of the table. Column
