Is there a way to keep display name for KPI list in view?
  • July 5, 2022
  • 60 views
praveen.ojha12
Level 6
I have created a KPI list in the view using the existing KPIs in the Knowledge model. Since a KM is connected with multiple Views, thus a KM KPI is used across multiple Views. But I wanted to have different display names for KPIs depending on the View it is connected to.
Is there a way to do that? Screenshot for you reference.
  • Level 4
  • July 6, 2022
Hi Praveen,
It might not be the most beautiful solution but I would suggest to simply recreate the KPI and give those the desired name for the corresponding view...
We were also noticing that what you mentioned above is happening and for the time being we opted for the way I described above (not beautiful, but it does its trick...).
Hope that will solve your issue for now until it is possible!
Denis
Maybe extending the KM? that way you will get the original KPI and will need to change only the KPI name...?
