I was looking for all possible process connectors on Celonis but could only find a few. Celonis claims they have over 100 process connectors, so I was hoping to know which process connectors are available.
Hello Syed,
The EMS for now contain about 59 process connector, and more then 209 apps. the best option is to check EMS store, if it doesn't satisfy you you can also write to celonis support. Sometimes there are some process connectors not placed in EMS due to different reasons.
Most of them are not well documented, but i found some documentation for all SAP related.
<your celonis link>/help/display/CIBC/Process+Connectors+Best+Practices
Here you can find table requirement - most of connectors should be visible here, maybe even if they are not curently available in EMS store.
<your celonis link>/help/display/CIBC/Table+Requirements
Mateusz Dudek
