I’m trying to configure an input checkbox component with a chart/kpi
I’m not getting to configure it correctly. I’m unable to use sharefilters attribute in kpi list
any help on configuring this component will be helpful
thank you
thank you
Is this what you are looking for ?
Yes @Abhishek Chaturvedi
but I configured in the same way
but the value doesn’t change when the input checkbox is checked
Have you created the variable as well ?
Yes @Abhishek Chaturvedi I have created the variable as well.
