I have done to create tables and charts in view but how to add table border margin colors and in charts & graphs section how to add in different colors.
Hi @sanati.dines , in Views for charts you can choose different colors from the color scheme available in visual or code editor
using Visual editor: click on General settings at the top right -> under the Color Scheme for Layers click on the dropdown and choose the desired colours.
To add colours to Table component in views:
you first need to create a custom object in Knowledge Model by defining the display details you need.
Refer Display Rules content in help resource for complete understanding.
HTH
HTH
can't we customize color, which we want?
you can choose from one of the available color options in section Chart customisation option
https://docs.celonis.com/en/charts.html
