I have a problem with a KPI-DIMENSION common table
  • July 26, 2024
  • 11 views
arturo.orteg11
Level 3
I'm using a dimension which is based on KPI which contains different tables IDs (e.g: matnr from marc, ebeln from ekpo...) I´m trying to use this dimension whit a KPI (inventory on hand). This KPI is formed the following way:
COALESCE(
  PU_LAST(
    "MARC"
    , "STOCK_HISTORY"."VALU_LBKUM_CON"
    , ORDER BY "STOCK_HISTORY"."EVENTTIME" ASC
  ) -- Ascending order is considered. Hence the result is the last eventtime (and therefore most recent) in the table per Material || Plant.
  ,0.0
It is giving me a problem of common table, but I thought that by stablising MARC as the common table with pu_last it would work, as it is working with other KPIs made the same way.
Hope somebody can help me here, thanks
thomas.guerr
Level 7
Hello Arturo,
could you please provide some further details about the data model you are working with?
What is the relation between MARC and STOCK_HISTORY and is there a Case Table in-between?
BR Thomas
