How to ingest semi-structured or unstructured data in celonis?
Do they have any connectors for Mongo DB
Hello Akshata,
what use cases are you thinking about for which you need semi-structured or unstructured data in Celonis (except ML)?
You can connect to a MongoDB via the JDBC interface.
Furthermore, you have the possibility to either search for documents in a MongoDB or to read, insert, modify or delete a document via the action flows.
Kay
Hey Kay,
Thanks for your response !
Actually I was only aware about the three styles through which we can ingest structure data, so wanted to know how about semi structure and unstructured data
Can you share some links or tutorials for the same it would be helpful :)
P.S - I am a beginner in Celonis
