I am trying to fetch real time information from Oracle EBS and want to use Action flows to send an email if there is any entries being wrongly created.
While using EBS Node to connect the DB , it looks for a connection.
I created the connection , but the same do not appear in the list.
Anyone - Have you ever connected Oracle EBS from Action Flow Node? please Help
Dear Ayan,
Thank you for reaching to us.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description.
We will gladly assist you.
Thank you in advance.
Regards,
