How to Calculate Total Amount with Multiple Filters, Each with Three Constraints?
We want to write a formula to collect the NOV amounts of the people with all two constraints, can you help?
CASE WHEN "_CEL_P2P_ACTIVITIES"."USER_NAME"='X' AND ("_CEL_P2P_ACTIVITIES"."ACTIVITY_EN" = 'Submit Purchase Order') AND "_P2P_TCL_POSITIONS_V3"."eylem_sahibi_division" = 'CORPORATE LEGAL AFFAIRS'
THEN KPI(NOV)
WHEN "_CEL_P2P_ACTIVITIES"."USER_NAME"='Y' AND ("_CEL_P2P_ACTIVITIES"."ACTIVITY_EN" = 'Submit Purchase Order') AND "_P2P_TCL_POSITIONS_V3"."eylem_sahibi_division" = 'CORPORATE LEGAL AFFAIRS'
THEN KPI(NOV)
ELSE 0
Hello Hande,
If I understood the issue correctly, you could simplify your code if all other conditions are the same by including only one condition by using the operator IN like:
CASE WHEN
"_CEL_P2P_ACTIVITIES"."USER_NAME" IN ('X','Y','Z'.....)
THEN KPI(NOV)
ELSE 0
Hope this helps you solve your issue.
Pablo
pablo.maced wrote:
Hello Hande,
CASE WHEN
THEN KPI(NOV)
ELSE 0
Pablo
Hello Pablo,
First of all thank you for your answer, but actually I need a formula where all other conditions ( activity & position) are also variable/changeable.
I would be very happy if you have a chance to support me in this matter, too.
Hande
Hello Hande,
In that case you just need to follow the syntax of the CASE WHEN function (https://help.celonis.cloud/help/display/CIBC/CASE+WHEN) and apply the logic needed for your given case.
If all other conditions can be variable but they do not need to match a given combination the can be grouped in similar example that I gave you with the use of operator IN.
If only a given combination of variables should be valid, in that case you need to nest multiple conditions similarly to what your initial approach was.
Pablo
